bigjohnson
I tried to start this motor (after carb rebuild etc) and it started for a few seconds then dies. I check the spark plugs after pulling the crank and it seems to be getting too much fuel (wet plugs). I think it's the primer assy. Is there a primer assy rebuild kit? If the "orings" inside the primer are faulty would this cause too much fuel to dump into the engine? I think all the factory settings on the carb were correct. (This is the way I bought it). Is the idle adjust screw 3 turns or 5? Float bowl level height?
