chris_holt
"This engine is low hrs and in
"This engine is low hrs and in meticulous mechanical condition. Suddenly it began having cold start issues. Turn the key and it fires instantly and runs 10 sec. then quits. Runs 10 sec. then quits. etc. If I play with cold start lever, I can make it run at 2000rpm and it will stay running with the check engine light and buzzer on. It will run like this for 30-45 sec., then light and buzzer goes off and engine runs perfectly all day. Next morning, same thing. The ECU is storing no codes, and all sensors have been tested and are within specs. ie:cam sensor, crank sensor, MAP sensor, IAC, closed throttle switch. The only sensors I can not find test procedures for are the intake air temp, and cylinder temp. Is there a possibility that the IAC is in spec, but not functioning properly,or what else can cause the ECU to prematurely terminate the cold start map."
