When I turn the key to the on position it does its usual beep. Then when I go to start it...nothing. When it returns to the on position it beeps again. If I fiddle with the key a little I can get it to turn over for a brief second. This leads me to believe it is probably the key switch that needs replacing. Do these commonly go bad? I also will check the wiring around the throttle to make sure there is no visible wire damage.
My other question is can I pull the plug out for the key switch and use a wire to arc the different ports and try to start it that way to confirm that the switch is bad?
Thanks for the help?
