whitegreg56
A little background...we've had some cold-start problems. Sometimes it would take 20+ pulls
to get it started. Other times it starts on the first pull. Suspect the primer has a problem
because after a tiny spray of starting fluid into the intake, it starts right away. The engine
runs perfectly in every regard, once it starts. Once warm, it starts on the first pull, every time.
Since it's an old engine (we bought it new) and used quite a bit (the sailing club), I figure
the primer diaphragm may have a problem. So, I bought a "kit" 1395-9761--1.
There is a little paper note in the kit that says "CAUTION, When changing the injector
diaphragm you MUST change the injector spring and plug". It looks like the diaphragm
can be replaced without removing the carburetor. The injector spring and plug doesn't
look so simple.....do I have remove the carburetor? Why does the injector spring and
plug need to be replaced?
