flatheadcat78
"Hey guys, A buddy of mine brought his yamaha 50 2stoke over to me for some help. Motor was very rough running, Idle was very poor. Anyways I cleaned the carbs(In Carb soak). He also wanted a new pump so we did that. Well all buttoned up I busted her off on the hose. Ran well for a few minutes, then started to load up.Bottom plug pretty wet. Little bit of checking, notice fuel pump vaccum port was wet with fuel.Put a new pump on it. Now it starts and runs ok, coughs and spits, idles down some and shuts off. Plugs are a little wet, not soaked. The motor seems ok above idle, it will acell like a raped ape! Just the idle. I have cleaned carbs like these hundreds of times, I know I might of miss something during the cleaning. But normally that would cause a lean condition not a rich idle. We are missing something I know, Spark is also strong. Any ideas?? This motor also has the CDI with the electronic advance. Could that be it? Thanks again for any help
