Sorry if I post this twice I am new to the forum and I did not see the first attempt show up:
I am new to he IO world. Were I live we do not get too many freezes. Long story short did not remove all drain plugs. Found port side core plug out. Replaced and found 5 inch horizontal crack in block same side just a drip though. Going to attempt JB Weld till I can save for new block.
So far I have cranked an ran 2x for about 20 min. on muffs. (sounds good)
No change in oil color or amount.
Temp is ok on gauge
oil pressure is high 80 until warm then drops to 75
starboard riser is hotter and when i blow through hose to manifold it has more resistance and very little water coming out starboard side of outdrive
a little oily film noticed on ground behind prop.
I have ordered new riser gasket so I can inspect riser
I am checking cylinder pressure this week
Any guidance and comments welcome. Not sure what my chances are and what to do next to try making through this seasons
Once again sorry if this goes up twice
Temp is ok on gauge
