I have boat that has a 98 4.3 mercruiser. Last year my alarm went off for high temp it was right at 205. I shut the engine off and let it cool down then restarted. It slowly started going back up so I parked it and replaced the impeller in the foot. It still looked brand new but it had been about 3 years since I changed it. When I tried it again it didn't over heat but it would get up and run about 180 at idle or down river. When you would stop the temp would creep up to 195 but then it would go back down to 180. I then changed the thermostat it had a 160 deg in it so that is was I put back. Still same problem. This year after looking at the engine I saw that the weep hole had a little bit of water weeping out of it on the front circulating pump. So i changed that. When I tried it again it would do the same warm up to 180 then creep up to 195 after i had been running it down river and would stop and let it idle but it would go back down or I could take it out of gear and rev it up a little then it would drop back to 180 quicker. I had not really paid attention to the temp gage before this other than making sure it was not over heating so I don't know if this is normal. I thought about changing the temp sending unit to see if that might be a little out of whack other than that i could use some help. So far I used all mercruiser parts also so no weird aftermarket parts used.
