"i have a 1998 225hp merc that
"i have a 1998 225hp merc that fould plugs on cylinder #2 and #4 ,it would not start unless it is trodle up , when start it smokes and if trodle to idle it spit and spatter then cuts out,it also give and intermitten beep ,it will run once in gear ,but will not reach top end speed,i check for spark and compression all same to be good (90psi on all cylinder). could this be injectors ,reeds, or tps."
