I replaced my waterpump this year.
When I dropped the LU, it was in neutral; when I put the LU back on (with gearcase in neutral), the hole in the shift rod lined up fine with the shift lever in the motor, and the bolt went in through the eye of the shift rod no problem.
Tested shift on the earmuffs, no problem.
Put it in water for season yesterday. Motor starts in neutral, shifts into forward, and shifts into and out of reverse.
However, when coming down in RPMs in gear and into neutral, about half the time it doesnt click right into neutral. A minor jerk of the binnacle toward reverse and it finds neutral fine. Other times, it finds neutral with no problem.
Do I need to drop the LU to adjust shift rod height, or can I make a cable adjustment (or another suggestion)? I also noticed the binnacle doesnt feel like it has the same "click" when coming down from fwd into neutral. Obviously, I imagine it's connected to the waterpump service, but I should mention my cables are not new...
TY for any help!
TY for any help!
