Hi,
I have had this motor for about 15 years now, and for the most part it has been great.
Ever since I got it is had a slight miss around 4300 rpm, sounds like a cylinder drops out and
at first it was very specifically at 4250 to about 4300 rpm, but will run ok below and through it up to 5000 rpm.
over the years, the "dead zone" has slowly expanded.
after years the band increased to about 100 rpm, the 150 now is abut 200 rpm.
we have done a lot n the fuel side over the years with no change to this issue. 90% sure it is electrical.
added an inline fuel/water separator, cleaned and set the carb many times, replaced internal fuel filter, spark plugs annually.
The CDI ox was replaced once about 10 years ago as well.
The issue is bad enough now, that I think the next drop will leave me unable to get through the "dead zone" and above 4200 rpm
was going to begin my way through eliminating electrical components and was planning to start with the coil.
anyone seen this before and have any insight where to start or troubleshooting methods?
it can get pricey fast just swapping components.
Thanks !
Thanks !
