1997 Yamaha Salt water series
chugger
outboard using excessive fuel
outboard using excessive fuel & at 4000rpm top speed 18mph should be 36mph plus plugs removed saturated what is cause has been operating ok before this}}
"what HP?
bad fuel pumps, i
"what HP?
bad fuel pumps, if using more fuel
E-Z test
run motor at idle for 30 seconds
pull spark plugs
if wet, bad fuel pumps
E-Z-er test
pull fuel pumps, 2-10MM bolts
pump fuel bulb, if you see fuel weep out of pulse hole (between 10MM bolts) bad pump
i like spark plug technique , no gaskets replacement needed!
E_Z"
