1997 suzuki dt140 lower unit removal
kidwkr
Hi,,i will be attempting to remove lower unit and change impeller. This will be my 1st time removing a lower unit. The manual is somewhat limited on instruction. Is this a relatively easy job, or something better suited for a marine mechanic?? Thanks in advance..bob
Nothing to loose and everything to gain.-------Take out the bolts and the lower unit will come down. -An assistant will help with operating the shift control.----------When lower unit comes down you will see the shift rod connecter and you remove a pin.----Certainly no need to pay anybody for this simple work.-------------Parts diagram is at -----boats.net
Racer. Thanks for the response..encouraging. so it sounds as if theres no draining of the oil. Just drop lower unit and the pump plate should be visible..
