Hi all - hope you can help.
I have a '97 Lund 1800 Fisherman, Mercruiser 3.0LX, Alpha One (Gen 2) with power steering.
While under power, the boat leans hard to starboard. When looking back at my wake, I noticed something was definitely not right - I walked to the back of the boat, looked at my outdrive and it was turned toward the starboard side... as if I had the steering turned to that side.
After reading a few posts on this forum, it seems like I may need to adjust my zinc anode with the trailing edge of the fin towards starboard.
I have had to put new props on the boat a couple of times, and have never adjusted the anode. I do have one fin on my prop that is curled a bit from hitting something also.
Can that little fin (anode) really cause the outdrive to kick to one side like that?
If I had saturated foam, I understand that may cause the leaning but would it also cause the outdrive to kick to one side like that? The boat seems to be level when just sitting in the water.
Is there anything else that would cause the outdrive to kick over to the starboard side while under power?
Thanks - Glen
Thanks - Glen
