1997 Seaswirl cuddy
I have this tank built in I removed the gas pickup tube it has a kink in it. The new ones are 12 inch long the one taken out is short. Can you cut the new one to length? How many gallons does it hold ? Thanks
Cutting a new dip tube to length is normal...
as far as capacity, assuming the tank, there should be a label on the tank from whoever made it...
measuring the tank will get you a reasonable estimate of the volume it will hold.
a quick poke on the WWW suggests between 24 and 36 gallons.
