1997 mercury tracker 40hp is not shifting from forward when shifted to neutral nor reverse
does the shift rod to the lower unit go up and down when you shift from forward to reverse? The shaft starts at the junction under the carburetor and goes down the front of the leg to the lower unit, check to make sure something simple hasn't become disconnected before you assume the worst.
