hi all , 97 mariner 45 jet engine runs great tell warms up.i have replace the key ignition,starter solenoid,#2 coil,new coil wires, new sparks plugs,and the stator.i did the test on the stator all ohms n voltage are good. did the trigger and all good there . coil #2 was weak spark.engine start good when cold but after 2 to 4 mins it just die fast, i clean the fuel pump and filter did the same thing, so i bipass the fuel pump and still the same .the charging regulator is charging good , its coming down to the switch box or the trigger i think,.need help plz thanks you all
3
3
