1997 Johnson Wont Run
jon_gore
I have a 1997 Johnson 115 hp m
I have a 1997 Johnson 115 hp motor that will start when the primer key is held down and it will run for 10 to 15 seconds and die out. I cleaned all the carbs and replaced the vapor separator. Could the fuel pump be shot. I believe its not sucking gas on it's own. Any ideas or suggestions would be greatly appreciated.
Before keep on testing be sure
Before keep on testing be sure You use premixed fuel. If VRO not working -no oil!
Try using the primer bulb as pump and see if that helps.
Thanks for the tip but my engi
Thanks for the tip but my engine has oil injection with it's own oil reservoir so I can't mix the gas my self. I tried using bulb to keep it running but had no luck with that either. I hope I can figure it out soon or I will have to take it to a dealer.
"did u just get the boat?....a
"did u just get the boat?....alot of people are'nt sure about the starting procedures..u know,u need to 'feather' the choke a few times till it runs on its on..right?....that means to push it in and realease 3-5 times,right after starting,depending on weather,and engine.....try it."
"also,..u did adjust the low s
"also,..u did adjust the low speed needles right...about 3-5 turns out ,run and fine tune."
"I bought the boat new and I h
"I bought the boat new and I have never had this problem before. It ran fine last fall when I winterized it. The carbs were awfully clean, but they did seem a bit oily? I did not mess with low needles. Should I try to run it from a fuel source other than gas tank in boat? Maybe gas in tank is no good. Thanks jwbmarine."
"This engine should have a &#3
"This engine should have a 'quick start' feature. As soon as started, no need to keep feathering the choke when first started. Use a 5 gal can with premix for testing, or add oil in the fuel tank giving 2% mix until problem is solved. Just leave the oil tank as is. There is no 'oil injection', the VRO mixes oil in the pump chamber before fuel gets into the carbs."
"the quick start---has nothing
"the quick start---has nothing to do w/the carbs....it advances ignition only,..feathering the choke,will def help ."
