trynhooker
This engine has the optical ignition. The owner prior to my customer removed the rect/reg.
Owner states that he runs engine a while THEN it shuts off completely. And when he tries to restart there is NO SPARK on any cylinder.
After it sits about 20 minutes, it magically fires back up.
He states when it happens he doesn't wiggle wires etc incase of a short, he just fishes and tries to start later.
He's also replaced stator, sensor and tried it with a swapped power pack, yet with all that it still has the same problem.
I'm running engine trying to see if happen but not seeing it "yet".
Tested kill wire for voltage with key on and no volts. Only thing I've noticed with that is when cranking obviously voltage spiked up... normal, but when I turn key off the voltage doesn't drop to 0 immediately? Maybe that's just my meter slowly grounding the voltage back to 0?
Any thoughts?
Any thoughts?
