1997 johnson 200
ted
"Just cleaned and rebuilt carb
"Just cleaned and rebuilt carbs,(3 idle pickup tubes gumed up).did not remove throttle plate,did remove idle circuit cover plates cleaned and blew out,(thay were clean),did not touch idle adj screws,motor idles smooth for the most part and makes good power through power band,I think 1 carb is alittle lean because motor sneezes every min or two,is there a way to tell which one is lean or open a little and wait, 1 at a time till trouble clears THANKS TED"
"Ted, Spray a little 50::1 pre
"Ted, Spray a little 50::1 premix into each carb, and see when it doesn't sneeze anymore. Or you might try to cover the intakes alternately, with two fingers and see when the sneeze stops."
