1997 Johnson 175HP starter problem
whaler23
"Thought starter was bad, remo
"Thought starter was bad, removed and bench tested, works fine, draws correct amps, etc... Before replacing it would not turn engine over, battery fine, etc... Now after removal I reach into the hole that the starter drive gear (13 teeth) goes into and notice I can freely spin the gear the starter gear would mesh with. I can spin this gear either way, now I know somethings not correct, replaced the starter and it spins and free wheels the gear it meshes with, no engine turnover. Any ideas before I remove the flywheel cover and start inspecting?
I'm referring to the gear that sits inside the flywheel housing, not the drive gear attached to the starter shaft. I put my finger through the hole into the flywheel housing where the starter shaft would go and I can spin the gear with my finger, this shouldn't happen unless I'm missing something... I'm wandering if something is broken inside the housing and what it could be? All the teeth on the gear I can feel with my finger are intact and do not appear worn at all.
Update on the starter. The starter shaft isn't the type that has the drive gear spinning up and back to engage the flywheel gear but rather it's fixed in place with only a tiny bit of movement on the shaft. I disassembled the starter on the bench last night, brushes looked good, springs not worn, armature and magnets new and not a bit of corrosion anywhere. Re assembled and works fine on bench. Somebody must know something about the free spinning gear issue inside the flywheel housing, it looks like two gears take the gear from the starter and transfer it somehow to the flywheel so something must be broken inside this housing. What mechanism, clutch or otherwise, moves these gears off the flywheel once the stator charges the power pack enougn to provide ignition. I do have a repair manual ordered but as you can guess it's not hear yet and I'm very frustrated with this one."
"Happens from time to time tha
"Happens from time to time that friction clutch slips in assy: 0434517 (#17)
Have to take off the top plastic cover to change."
"Thanks for the response. Is
"Thanks for the response. Is the fix simply resetting the assembly or is something typically broken on it? Ordering new looks like 121.00 or so, what part would have slipped?"
"It is an internal part of the
"It is an internal part of the gear, friction clutch, which is not serviceable. Complete part has to be changed.
Normally You may hear the starter engage and run, but fly-wheel does not turn."
