champion186
Heres a good one for ya...
J175GLEUC 1997
Last fall I found water in my lower unit while changing out before the winter. I (well a boat mechanic) did a preasure/leakdown test and both passed. He said it's possible that it could be the plastic washer at the fill was bad (where the pump was attached) So we went ahead and did the water pump while it was off. He stated that he wasn't a fan of the plastic washer style and liked the rubber o-ring. So I switched them out, and put her away.
After My first trip out this year I cracked the lower and I found the milk shake again .
I dropped my lower unit off to a different mechanic and he did all the same test, held pressure over night
even. He also sealed up where the speedo gets its water (don't really know what to call this) He said its the only other place he could think of. He shook the drive shaft, shift shaft and could not get it to loose pressure. Well I took her out and yep.....found water again!!! What am I missing??? He is just as confused as I am.
J175GLEUC 1997
