G
Grover Sheldon
Guest
" Just bought a used boat whic
" Just bought a used boat which ran fine for some months; however, recently when trolling or idling for any length of time the engine begins to run rough and the engine speed goes to 1500 to 2000 rpm. I have changed all plugs, new fuel filter, all new gas with injector cleaner, cleaned the injectors with cleaner at the solenoid port, cleaned the filter at the engine, and cleaned what I could of each intake bowl with carb cleaner, inspected all the fuel hoses for kinks and collapsing. Seems after I advance the throttle, the hesitation can go on for 4-5 minutes then the engine roars to life. Yesterday when this happened, I removed the motor cover and I could advance the throttle with good response by moving the throttle bar on the engine itself. This left me really puzzled. Could this be an electronic problem or spark advance problem? It is really frustrating since the problem does not happen all the time and did not happen when I took it to the local J-E shop. Your input would be greatly appreciated.
Thanks "
Thanks "
