1997 Evinrude Intruder 150 runs fine but occasionally will go into SLOW mode.
jessejames28
My Evinrude Intruder 150 runs great for the most part, but when I run it a WOT for about 10min it will go into SLOW mode and fall off plane suddenly. After coming off plane it will kick and flutter if you try to get under way again. If you turn the motor off and back on it seems to reset the system and it will run fine again for a little while then it will do it all again. It has done it once after only running for about 3-4min and it only does it at higher speeds (50-60mph). In order to make it back for weigh in the other day when this first started, I simply stayed around 45mph. The tach quit working about 2 years ago so I don't know exactly what RMP this occurs at but I know its not going over 5500. I'm pretty sure the voltage regulator is causing the tach issue so is it a possibility that it could be the culprit?
model number: E150ELEUE
Boat: Javalin 379 se
I printed out the instructions for testing the power pack with a volt/resistance meter today so I’m going to do that tomorrow and see what I come up with.
Does the warning horn Beep momentarily when you turn the key to the ON position? If not... your water pump needs replacing.... and even if so, if it were me, I'd drop the lower unit to check that pump as that's exactly what your explanation spells out!
The Tachometer hasn't worked for two years... and you're ignoring it? Are you looking forward to that engine catching fire? Read the following...............................
(Testing Tachometer With Water Cooled Regulator/Rectifier)
(J. Reeves)
A quick check is to simply plug in a another new tachometer as a piece of test equipment. If the new tach works properly and the old tach didn't, obviously the old tach is faulty.... but usually boaters don't carry around a spare tach (see below).
A faulty rectifier wouldn't damage the tachometer, the tachometer simply wouldn't work. This is due to the fact that the tachometer operates off of the charging system and the rectifier converts AC voltage to DC voltage, enabling the charging system. A faulty rectifier disables the charging system, and the tachometer simply doesn't register.
However.... those water cooled regulator/rectifiers that are used on the 35 ampere charging systems (and some others) bring into play a different type problem, and as you've probably found out, they are really a pain to troubleshoot via the proper procedure. There's an easier way.
The tachometer sending/receiving setup operates off of the gray wire at the tachometer. That same gray wire exists at the engine wiring harness which is connected to the engine electrical terminal strip. You'll see that there is a gray wire leading from the regulator/rectifier to that terminal strip, and that there is another gray wire attached to it. That other gray wire is the wire leading to the tachometer which is the one you're looking for.
NOTE: For the later models that DO NOT incorporate a wiring terminal strip, splicing into the "Yellow Wire" mentioned will be necessary.
Normally the Gray wire leading from the tachometer is attached at the terminal strip to another Gray wire which leads from the water cooled voltage regulator/rectifier...... remove the gray wire that leads to the tachometer. Now, find the two (2) yellow wires leading from the stator to that terminal strip. Hopefully one of them is either yellow/gray or is connected to a yellow/gray wire at the terminal strip. If so, connect the gray wire you removed previously to that yellow/gray terminal. Start the engine and check the tachometers operation, and if the tachometer operates as it should, then the regulator/rectifier is faulty and will require replacing. If the tachometer is still faulty, replace the tachometer.
If neither of the yellow wires from the stator is yellow/gray, and neither is attached to a yellow/gray wire, then attach that gray tachometer wire to either yellow stator wire, then the other yellow wire, checking the tachometer operation on both connections.
I've found this method to be a quick and efficient way of finding out which component is faulty.... the tachometer or the regulator/rectifier. It sounds drawn out but really only takes a very short time to run through. If the water cooled regulator/rectifier proves to be faulty, don't put off replacing it as they have been known to catch on fire with disastrous consequences.
The water pump was replaced when I rebuilt the lower unit a couple months ago and I'm getting good water pressure, so that can't be the problem. And this shouldn't be a water cooling system issue because the motor never runs hot when it happens. As for the rectifier I'm going to test it using those instructions. I would have fixed that a long time ago but I wasn't sure how to determine which was the problem.
