"1st time poster but have reli
"1st time poster but have relied on board advice previously. So, rebuilt both sides of the fuel pump (air motor and fuel diaphragm) couple of weeks ago. Oil feed disconnected and just running pre-mix. Here is my problem and the recent history:
1. After fuel pmp rebuild, was producing a lot of white smoke. Thought it was steam but:
2. Was able to run the boat on the lake today (gorgeous here in New Orleans). Boat ran great for 5 minutes at about 3,500 rpm. After 5 minutes or so, I opened it a bit more say 4,500 - 5,000 rpm. After a couple of minutes the RPM started to drop 500 rpm then jump back up, then down then up.
Got scared of being stranded so backed down to 3,500 and headed to the dock. Ran pretty good.
Noticed excessive fuel in lower cowling and discovered cracked fuel fitting where fuel hose connects to front of cowling. Fixed that and went back out. The "steam" disappeared so think the motor was leaning out. Only ran the boat for 10 minutes before fixing the cracked fitting so hopefully didn't burn it up. Fuel ball was "normal" when I reached the dock, nothing like when before the fuel pump rebuild. Not hard as a rock but not empty either.
Relaunched and same thing. Ran great for 5 minutes at 3,500 rpm or so but when opened it up to 5,000 rpm, lost 500 rpm or so then jumped up, the dropped, then jumped, then went back to the dock.
My 2 thoughts are: junk in carb bowls that get sucked in when turning hi rpm or electrical issue.
Any thoughts. Sorry for the long post but wanted to give full picture of the situation."
