1997 E225txecs Johnson problems need Help
retiredDon
I went out the other day and she started fine. As soon as I started to power up she ran nice 30-31 mph at 4900 rpm's. When we slowed down she was fine then when we went to take off we had it floored doing 8-10 mph and it would only go to 4000 rpms. When we powered down to 2000-2500 rpms we did the same speed.
Before it goes to the mechanic for a look see I'm hoping someone can guide me in the right direction.
The Johnson is pushing a 24ftWellcraft Coastal
You may have lost spark on one of the cylinders. If you disconnect one spark plug lead at a time (and earth it to protect the coil) you can see if things change and identify the cylinder causing the problem if that is what is going on.
Stuart
