1997 BF90 lower unit seal kit options
bmoreboater
I lost the o-ring on my shift shaft holder in my lower unit. Corrosion caused the oring seal to fail and I am looking to replace it. I was considering resealing the entire lower unit and am adding up all the different seals as I do not see a complete seal kit. At well over 200 for all the seals alone I thought that was a little steep for the parts I am getting. I have read that the lower unit is from mercury, is a seal kit from Mercury available that will fit this lower unit?
Thanks and any help is greatly appreciated
thank you for the reply, I was using Partstree and was closer to 200 with all needed parts. I am seeing complete reseal kits for the comparable mercury lower units for around 50 bucks and thought that may be an option. thanks
