1997 90HP Force Lower Unit Forward
I replaced a lower unit. Lower unit was used, installed new water pump,impeller, and lower unit oil. After installation the propeller turns in forward gear, when shifted into reverse the propeller continues to turn forward. In neutral the propeller turns. I am assuming when the lower unit was side into place the shifter was in forward and gear unit was in reverse??? How do I get neutral, forward and reverse gear?
