Mechanicalpeachz
I just bought a pontoon from a gentleman that was a mechanic, as am I, but I dont work on marine engines, let alone outboard motors. The previous owner did a lot of work to the motor and im not sure to what extent his work went. He told me it would run but misfire after getting hot. When I got it home, it wouldn't run at all and had no spark. Replaced the trigger assembly and now has spark. It still will not start. I'm getting fuel to the carb but im not 100 percent sure it's getting to the cylinders. I'm going to test the compression once I find my tester, but I believe the compression is fine. Any other advice is greatly appreciated. THANK YOU IN ADVANCE!
