1997 57 prop
blaneryan
"Hello i have a 97 2050 capri,
"Hello i have a 97 2050 capri, 5.7 i beleive 220 hp..The boat runs excellant however i would like to find a reasonably priced prop that will enhance the overall performance of the boat.. Any suggestions would be appreciated"
"I've personally tried a 4
"I've personally tried a 4 Blade Piranha Propeller, my nephew runs a 4 blade 22p on his 5.0L GM/Volvo Penta 20' 2008 Glastron 205GT. Lifetime warranty on the hub and the blades are from 13-20$ each. Super easy to change blades for the day or if you damage one, I damaged 2 blades one day, had minor vibration and no damage to the drive. no spares at the time either."
"Ryan:
Are you sure it'
"Ryan:
Are you sure it's a 5.7L? They are usually 250-260 HP. The 5.0L is a 220 HP. What does the label on the flame arrestor say?
Input your data on this spreadsheet from Rod Stewart.
<center><table border=1><tr><td>http://www.marineengine.com/discus/icons/mime_msexcel.gif""" align=left alt=""application/vnd.ms-excel"">prop finder
[url=""][b]Copy of Copy_of_Boat_Speed_Finder-79780-193827.xls[/b][/url] (26.1 k)</td></tr></table></center>"
Thanks to all for your reply..
Thanks to all for your reply.. I do know that it is a 5.7 i just guessed the horsepower.. I don't know the actual hp for the boat. I have had the boat going 58mph alone in it i weigh 260. However i would like to go faster!!!!
I'm having trouble understanding the spreadsheet??
"210-220hp generally means you
"210-220hp generally means you are running a two barrel carb, either way what prop is on it now??"
"Ryan:
Send me the followin
"Ryan:
Send me the following:
boat's average total loaded weight w/passgrs., gear, gals. fuel
where you boat
HP from label; 2 or 4 barrel
OD ratio"
