Darren Gillon
My name is Darren and I like in the Northwest coast of Australia. The water temp here is about 30 deg centigrade.
I have a 1997 5.7 LX with thunderbolt V ignition on it. I run the engine in a 7.2m Fiberglass boat and are experiencing some issues that I think might be ignition based. When I go out the engine runs fone for a while ( 1hr or so ) and then it cuts out. ( I usually run at around 3300 rpm - 28 knots ). It used to run on and diesel but I fixed that by running a cooler thermostat and adjusting the baseline ignition advance slightly. now it just stops. After it stop you can restart immediately and it runs fine. It will then run for another hr or so without fault. I'm at a bit of a loose end trying to determine wether or not it's the ignition module and wether or not the ignition module can be affected by temp. It seems to do it more the hotter the ambient conditions are.
Any thoughts would be appreciated
