Blackfin27
I have replaced the impellers on a regular basis. Risers and elbows are coming up on 4 seasons. Hours 780 +/- on the engines.
Recent slight steaming on one side, one riser and hose seems a little warmer, but no high temps. Fresh water cooled engines in salt water use.
Heat Xchangers and TBI injectors all new last season. This took care of several issues, including some high temps and fuel sheen in the exhaust outflow.
Engines 'allegedly' rebuilt 2014 +/-....mechanic suggesting new raw water pump assembly kits this winter, given age of pump assembly unknown. I am inclined to go ahead as it seems like good sense to know these get fully replaced given the unknown age of the current pump assembly.
I am asking the following given the above:
Any other major circulation/cooling functions to identify/replace while its torn open?
I am also considering another Riser job, (depending on Santa's generosity) would you go ahead with this with 4 years on em? Im leaning yes.
Should a head gasket job be considered given the steamer and some lower compression on that same engine?
( Im not good with tools BTW)
Thoughts and suggestions welcomed......TXS.
