Hello to all,
PLEASE HELP
I bought a 97 ocean runner 200 that had been sitting up for a while. The boat will run like a champ in the driveway but acts up in the water. Here is what has been done so far.
- checked fuel lines - cleaned carbs twice - replaced seals on carbs - checked pulse limiter - hooked up external tank- replaced inline filter to engine - cleaned out vro tank added fresh oil- link and sink- adjusted idle speed on carbs while on water - new NGK plugs.
Here are the symptoms. The first time out after reinstalling the carbs the boat idled and got on plane and ran wide open. This engine is a beast---> but When I put in neutral the engine shut down and it would shut off every time i tried to put it in gear. It fires every time I can throttle up with out engine being in gear and it will scream. When i shift into gear it bogs down and dies. Every now and then if i high rev and throw it in gear it will take off an run again.
Things I have Tried
When pumping ball while engine running it will not keep it running (doesn't help) If i hit key primer as it is bogging down it will come back to life at times. When I flip the primer (red switch) on motor when bogging down it will continue to run and not cut out. If motor is running and I cover each carb with hand while running it will pick up power.
Its like it is starving itself and i can not figure out why!!!!!!!!!!!
Now I'm thinking the fuel pump side may not be holding pressure. I don't want to throw parts at it until I hear others thoughts and have checked other possible causes.
Thanks for reading my book but I am trying hard to get this figured out.
T
PLEASE HELP
Things I have Tried
T
