magiccat381
I have a1997 Mercury 150 EFI that started cutting out after it has been running for some amout of time. The amount of time varies. Some days it does it a lot other days not so many. If it's idling haed headway speed to just above and it's starts to fade I can cut the thottle bad and sometimes get ti so run without dying. Other times I go to take off and the things just flat out dies. It will start right up every time and run fine and at full speed and power. I replace the primer bulb after finding it soft a few times with a attwood brand and the next outing the engine seemed to run great. I went out the second time a the engine started doing the same again. I thought maybe it was due to the cheap primer bulb but I'm thinking it's not now. It there an easy way to test for air leaks ?
