Hello - My 15 hp outboard will not stay running. I just rebuilt the carburetor and flushed out all of the orifices with carburetor cleaner. I put a new diaphragm in the fuel pump, cleaned and re-gapped the spark plugs but it will almost never start. I can pump the fuel line bulb until gas leaks out of the motor connection and the engine might catch once or twice but will not run steadily. I've tried adjusting the idle screw in and it seems to be a little better farther out when it will run, which is odd. Also, when it does start it will only start and run with full choke or with the choke slightly pushed in .
This is a very frustrating engine - it rarely has run smoothly in the six years I've owned it, but maybe most of that is my inexperience in servicing it.
Any direction would be most helpful.
domer7
domer7
