1997 115hp Evinrude E115TSLEU is over chargeing
seaswirl1850
"It starts out at about 13 vol
"It starts out at about 13 volts and works it's way up to 16 volts plus. What is wrong and if I run it like this, will it burn out the elect. system."
"It is fitted with a non regul
"It is fitted with a non regulated rectifier and that is the normal behaviour for those.
For reasons I know not the 25" shaft models were fitted with a more powerful stator coil and a (water cooled) regulated rectifier.
It might be possible to fit the reg/rect if you are really concerned but rest assured what you observe is normal for a non regulated rectifier.
Switch a bit of load on, the lights or something, that will pull the volts back down."
