Warm-up at house - starts 1st crank - while warming up the idle runs about 1800rpm - after 4-minutes warming up, it will "bark" and idle goes down to 1200rmp - then back up to 1800rpm, thereafter every 30 to 45 seconds it will "bark" again. Solid stream of water out the p-hole. When in the water, the idle problem is not so noticeable. The engine runs just fine under power. However, after running at 25mph for 45-minutes to the fishing hole and shutting it off - if you try to start it within 30-minutes - it is hard to start. Plugs are new, in-line fuel filter on the engine is new, water separator filter is new. Any assistance to help resolve the "bark" and hard "hot start" will be appreciated. Dutch1
