1996 Johnson/OMC 90hp v4 OceanRunner with idling problem
johnnyc2024
hello!
I recently re-built the carbs and haven't had it running/idling since...but it does sound like its almost going to idle, if that means anything!. I was told, from another contributor trying to help troubleshoot this (recently), to first check cylinder compression values. I obtained the four cyl comp ave values of 127, 135, 130, & 139 psi (averaged over 3 trials per cyl, 1s starter cranking per trial). If these values are good, can you instruct me on what I could trouble-shoot or adjust next? (Note, I'm using new fuel.) Should I be trying to check timing and throttle plate 'Synchronization and Linkage' nxt?
Thanks for any ideas/guidance!
