1996 Johnson 8hp Gear Shifter
I think there is a coupler in the shift linkage. Remove the bolts holding the lower unit on and let it drop down, shift the lower unit to forward or reverse which ever gives more clearence. Remove the lower bolt in the coupler.
If you have the 3 bolts out it should just slide down ----Drive shaft goes into the crankshaft.-----It is a splined joint.------Just give it a good tug.
I appear to have the drive shaft loose. It's the shifter shaft that that I am having troubler with.
