1996 johnson 70 hp fuel pump testing
P
Pipedream
Guest
I want to vacuum/pressure test
I want to vacuum/pressure test my fuel pump.The only limits I can find id for the engine running and warmed up. Is there anything I can do to perform a cranking test?
"sure...disc fuel line going t
"sure...disc fuel line going to carbs,and see if fuel come out while cranking..."
"Thanks JW. I gave it a try an
"Thanks JW. I gave it a try and am getting good supply to the bottom carb, mediocre to the middle and none to the upper. I ordered a fuel pump repair kit. Hope this does the trick!"
Did you remove the fitting at
Did you remove the fitting at the pump (one hose ) to do this test?.What is your motor doing to make you think fuel supply is the problem????
