Wildeyes216
Hi, just replaced head gasket and thermostat/housing gasket. Before the repair impeller was pumping fine. When I started up not getting any water out of house. Had muffs I've used several times that have always worked with an issue. Any idea?? Tested compression, both cylinders 95 psi. Is this good compression for this engine? Appreciate any thoughts! Thanks!!
