2250_stratos
Here is the story. Have not had any real problems so far this year. Its a 1996 Johnson 225 with a newer, used powerhead put on about 3 years ago. Never run it higher then 5000RPM, run reg unleaded all the time with treatment. When she turns on, I get alot of blueish smoke at first, then it cuts back to where you can hardly see any smoke at all, which tells me that I am getting oil in with my gas (it has the VRO system). OK.
The other day I idled out of my canal until I was out of the 5 mph zone, opened it up to about 4500 rpm for no more then 1 minute and a noisy banging noise starting coming from the engine. I pulled back on the throttle to nuetral, and still knocking. Turned around back to the dock. Idled all the way back, didnt want to rev it too high, but it didnt really seem to have lost any power.
With the cover off, it seems the noise is coming from the upper part of the engine, but its almost impossible to zone in on one section. It seems to be right in the middle where i would imagine the crankshaft would be.
My first thought was a bearing problem. Does anyone know how I could go about verifying this before I start pulling anything apart. I would like to be sure I know what the problem is before hand.
ANY suggestions would be a huge help. Cant get back in the water soon enough! Thanks
