I have a 1996 15hp 4 stroke th
I have a 1996 15hp 4 stroke that has given me a lot of trouble. The first problem was the rocker arms which was a common problem with this motor so I put in the upgraded arms. Then the motor would die at slower speeds. Then it would run perfect at high speed until you stop for a few minutes. When you restart it will not take gas and spits back. You can limp in and all of a sudden it starts running perfectly again. I cleaned carb and thought I had it fixed but it is doing it again. I use this motor in Baja and I need to get some trust back in it or trade it in. Any suggestions?
