1996 Johnson 130 under performing (J130TLEDA)
ccaron
I just purchased a 1996 Johnson 130 hp from a dealer after my Johnson 110 took a s***. My old 110 was very peppy and would push my boat at about 36mph if I trimmed it right. The new 130 seems sluggish out of the hole, and with a tail wind I only get 32mph. These motors are on the same boat, so I have a good comparison.
The dealer seems to think that changing the prop from a 19 to a 17 pitch is going to fix it all. I am skeptical. My buddies say that WOT my tach should read between 5300 and 5500 rpm. I went online and I THINK my motor is rated to max out at 6000 rpm. Right now, at my 32mph, I max out at 4600 rpm. I cannot believe that a prop change is going to get my max performance.
If the motor is truely rated at 6000, shouldn't my tach read as close to that as possible with WOT? How do I find out the true max RPMs?
If the prop gets changed to a 17 pitch, that would help out of the hole, but wouldn't I lose at the top end?
