surfsalterpath
re: 1996 FORCE 75hp cuts off when idling or going from F to R
These are the troubleshooting steps I've completed:
1: seafoam - yea, don't laugh!
1a: adjust all carb settings (never do this unless you know what yiou are doing!!!!) lol ~
2: new NGK spark plugs
3: new spark plug wires
4: new water separator
5: new fuel filter
6: clean carb
7: replace all 3 REED BLOCK ASSEMBLIES (yes 2 of the 24 reeds were gapped open a little bit)
since I am a "newby" outboard mechanic I forgot to put LOCTITE on the 6 screws holding
REED BLOCK ASSEMBLIES on the reed adaptor plate! dumbass me!
8: sync ALL settings: throttle arm and cam linkage, WOT, timing, idle mixture, idle speed etc
THIS WORKED, at first! idling GREAT @ dock and after 2 short test runs. BEST EVER!
9: Long "test run" 1 hr @ 5000rpms and return to dock and FORCE dies trying to change gears!
BUMMED!
next on the troubleshooting agenda I have not done yet:
a: pull carb and intake manifold to add the LOCTITE to the 6 reed block assemblies I forgot to do the 1st time!
b: replace the primer bulb fuel line hose going to the fuel pump with BLACK "368 series" fuel hose. I have
grey fuel line (2015) from water separator to fuel pump. FORCE forums say grey fuel hose is a no no!
c: rebuild the fuel pump with new diaphragm kit
d: replace the rest of the fuel line (fuel pump2fuel filter2carb) w/series 368 BLACK fuel hose
e: replace the recirculation one way valves and all recirc tubing
f: replace idle mixture screw and the inlet needle (tip wear??)
Ok, so what am I missing that I should consider to fix this "idle issue"
THANKS!
5: new fuel filter
6: clean carb
BUMMED!
THANKS!
