1996 force 120 flywheel torque specs
Mike1974
I recently recieved the replacement flywheel i ordered but cannot find the torque specs to install it. I would greatly appreciate any information.
I believe it's 85-90#
Just make sure the tapers are clean and dry.
I use valve grinding compound when I install another or new flywheel.
Smear the compound on the taper, install the wheel(no key) and turn it around and around and around.
Pull it and see where the paste has moved to on the taper.
It should be everywhere on the taper.
Clean it and install the key and new wheel.
A small amount of thin grease where the trigger rides.
