1996 Evinrude Ocean Pro V4 Port Balance tube not connected
Stephen Cutler
Where does hose #66 (Port balance tube) connect to on E90SLEDR?
Seller told me it had sat for 2 years. I took it to a shop. I got it back with original cracked, now undersized, cam follower roller, fuel filter not changed, and a disconnected vacuum hose stuck into the air silencer! It would only idle with the primer dump. I backed out the idle screws to 6.5 out & got it to idle, but it would stall going into gear. I put a piece of 5/16 fuel line over the cam follower core. That enabled the idle raise in neutral and fixed the die on shift. I still had fuel delivery problems. My OL Manual said replace hoses every 5-7 years. So I started checking hoses & discovered the disconnected balance tube. It was pulling a good vacuum. Needless to say I do not want to go back to that shop. I got a generic online manual which does show the starboard balance tube connects to a fitting at the lower crankshaft bearing, but it does not show where the Port balance tube #66 should be connected. The shop does not know and said to plug it and see what happens. Plugging it enabled the motor to idle, and get the idle screws back to 3.5 out. But I still have symptoms of a weak fuel pump & suspect wherever that hose connects to is depriving vacuum that may help drive the fuel pump. The VRO is disconnected & plugged. The weak pump symptom is - just before stalling from no fuel, pumping the bulb restores power. It will idle for more than 1 minute, then bog again. It will run WOT for less than 30 seconds, then bog again. I am suspecting a sticking vapor pump float pin, but without the hose #66 connected properly, I don't want to start tearing into the fuel components. My manual had a warning about running the motor with hoses disconnected or plugged.
I have already replace the rotted, fuel connector to fuel filter, hose & fuel filter. Marineengine.com shipped them to me 4 days ahead of schedule! The old one was full of decomposed hose particles
