I have a pair of 1996 Evinrude 225 HP OceanPro engines that have 500 hours and have been meticulously maintained. I recently started both engines and after a few minutes the Check Engine Light came on for the PORT engine only. The engine starts fine and when I idle it up and down from 1000 to 3500 RPM it runs fine and the engine seems ok.I have the Service Manual for my engines and I am aware that this usually means there is a fuel restriction, a bad vacuum switch or a circuit issue.
I swapped the STABOARD engine's vacuum switch to the PORT engine to rule out the Vacuum Switch. The Check Engine light came on with the switches swapped.
I did notice that when I turn the key to the ON position and the System Check lights all 4 LED's and then Beeps that the Check Engine light comes on before starting the engine. That seems it would mean something and I am wondering if anybody can tell me what it means if the Check Engine light comes on before starting the engine ??
THANK YOU !!!
THANK YOU !!!
