J
jim krzeminski
Guest
" My 1996 3cylinder 90HP engin
" My 1996 3cylinder 90HP engine will idle in neutral beautifuly and go in forward fine. When I shift into reverse the engine revs high, but doesn't engage. The cables look to be moving fine. Is there an adjustment to reverse I need to do. This problem happened suddenly. Where you disconnect the cable with the "locking black band" or clip, there are circular plastic pieces that the cables are connected to. One of them is cracked. Would that be a problem and what is their purpose? Thanks, Jim "
