1996 9.9 carb adjustment question
LUC_V
Hi, I have this motor that i use only for fishing (Trolling at slow speed most of the time). It run well but for reason after a short period of trolling it stops. After it as stop, I have to pull he choke to start it and after that it doesn't stay running very long.
I have clean the carb, change the plug and it stil do the same thing.
What I do not understand is that i have to turn the slow speed screw approximately 3 1/4 turns for it to idle properly instead of the 1 1/2 turn.
This is the carburator with the black plastic top with the idle Slow speed screw on the side.
Model is J10REOE.
Any suggestions would be appreciated.
Regards
LUC
Thermostat installed and operating properly ?----------------Compression tested ?------Fuel line and o-ring at fittings checked ?
