" I just bought this motor and
" I just bought this motor and was servicing it today (used Seafoam, changed plugs, gas filter, lower lube, and some electrical work). When I took the cover off and started the motor, I noticed that water was leaking out off, what I think is the water cover jacket. Not much, maybe a slight trickle.
Should I be concerned? How difficult to change the gasket? Looks like 14 bolts on each bank. Do the bolts snap off when trying to remove them? Bolts look a little rusty.
Compression is good: 120, 123, 125, and 127 respectively. Spark good too.
There is oxidation around the head gasket, but it is not leaking. Is oxidation around the head gasket normal?
Thanks guys (and ladies!).
NickyB "
NickyB "
